Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
06.06.2010, 10:13 PM
Aluminium would indeed be a bad upgrade choice, not sure what the stock ones are- probably just unhardend steel. Try and find some hardend steel versions from.. somewhere ( hpi forums may have some more specifc info or leads ).
FG101C
06.06.2010, 11:34 PM
http://cgi.ebay.com/HPI-102514-HD-Dr...item5192f1acdb
No more stripped drive gear. Works flawlessly.
scarletboa
scarletboa's Avatar
06.07.2010, 12:23 AM
I was having the same problem with my savage and the hd drive gear solved the problem. The stock gear is unhardened steel. The hd gear is hardened steel and will last longer than the rest of the truck.
Nixpus
06.07.2010, 02:51 AM
So the hd drive gear + the high speed 39t idler should result in a "bullet proof" center gear box locked in 2nd, right?
The point about bearings is certainly a valid one... Ive had more bearings than anything else fail in my truck. Now Ive made it a habit to swap bearings at a regular basis...
Tags
drive, flux, gear, stripped
