06.08.2010, 05:08 PM
Is that thing heavy for you to lug around? I reckon I'd pull myself over if I tried to pick one of them from a wheel chair
What clutch are you running? If you don't have one get a ceramic clutch. They are expensive but they last that much longer so the cost works out abuot the same in the long run. The advantages are not having to change the clutch so often and when it does die it is much less likely to overheat the shaft and bearings. I say this because a stroked motor with pipes is going to be a lot of grunt and you will go through the clutches fairly quickly.
I'm building it strong enough to pull ME out when I get stuck!
A clutch comes with the 30.5 so we'll see how she goes then I'll take your suggestion and go ceramic
looks great, i see so many of them clean and shiny with alot of aluminum, looks like you are putting it to work
Oh, she's for beating!! I hope to post vids soon
"the flash makes the silver aluminum look like black plastic"
Liar. I know black plastic when I see it. You just armorall'd it.
meanie
nice baja there harold!! a friend of mine has one with a CC racing engine in it and it has some nuts!!
enjoy brotha!
It's a boy then! I hope mine performs, I'm paying for the best.
These things are so easy to work on. They are black holes of money pits but I am having a blast building this thing.
