Jahay
06.11.2010, 10:11 AM
hmmmm thanks for the input alien!
My diffs are all nicely shimmed and they are the Bullet proof diffs so they should be able to take the force, and of course they are shimmed....
My only concern now is how well the ofna diff fits in the Universal RCM Motor/diff mount...
It is larger than the slipperential which means it could fit with little or no shimming correct?
And when you shim a diff, cant you only shim it so much?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.11.2010, 12:56 PM
Yep... shims are employed to reduce the effect of 'play' when the parts are bolted together, thus allowing gears/cogs to mesh well under pressure... there is also the flip side to that... over shimming, will create drag
through out the drivetrain (in this case)... it will then lead to lowered performance and even over stressed electrics...
Regard the universal RCM mount facilitating a 52 spur, have a look at the below post by paralyzed:
'Making a 52t spur fit'
Alien
