pritt
06.14.2010, 12:29 PM
OK.
I now carry this relationship:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Additional Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 18
Battery Voltage: 19.8
Motor KV: 1650
Tire Diameter (inches): 5.8
Top Speed (MPH): 34.9262 MPH
If you metiese the Traxxas slipper, with the largest cog, would 40T.
I would be:
Additional Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 14.1177
Motor KV: 1650
I've got one question:
The ratio is the same, but what affects the change made?
Does the engine run hotter?
Does the drive run hotter?
Greetings
