Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
bryan
bryan's Avatar
06.22.2010, 07:30 PM
He used an 8ight conversion. Mikes RCM conversion is much nicer and durable,and cooler looking!!!!!!!
XXXDAD
XXXDAD's Avatar
06.22.2010, 07:33 PM
I'm down to use Mikes set-up! Now what bumpers are those?
Did you see the new Tekin 550 long can SCT motors comming out in 4.5 & 5.5... thats what I can run and be in the class rules! Sweet!!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
bryan
bryan's Avatar
06.22.2010, 11:37 PM
You may want to have your LHS put that motor on order if you want one before next year.either one should work great depending your gearing-battery.
FG101C
06.23.2010, 01:59 AM
I would also like to know what bumpers those are. They look like Traxxas, but looking at amain's website I don't see them under Slash, Slash 4x4 or Slayer.
I flipped my arms, but instead of mounting the shocks they way he did it, I mounted them to the front side of the tower and stock position on the arms. The wheel base is now there, thinking either ProTrac wheels or m2c 17mm hex adapters.
Also the Slash 4x4 front bumper pretty much mounts right up.
What would be cool would be if you could post the link to that build from the Losi forum, because I can't find it on there anywhere.
XXXDAD
XXXDAD's Avatar
Lightbulb 06.23.2010, 11:48 PM
Nice job on the back end... shocks look like they are perfect. Now... can the droop screw be re drilled and taped? More guys more! Mine is here in 5 days...
think im going with 18t pinion to work with the R1 448 motor combo i already have. Then its the new Tekin SCT motor for me when they come out. M2C 17mm wheel adaptors and some prolines....
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
