I got the tekno hexes, yes they are drilled for 6mm axles. The Problem I found is the pins, they use the stock traxxas pins which are much smaller than the pin holes in the axles so there is alot of play. Going to try to dremel the hexes to use the tent pins.
By the way I HATE this POS iPhone, took 8 minutes to type this. POS does what it wants not what I want it to do, pretentious proprietary aholes.
