07.14.2010, 07:33 PM
A washer between the screw head and the mount. spacer would tighten/ pull the bottom of the motor into the mount, effectively making it like a normal mount that uses two bolts to hold the motor in place ( like an emaxx motor mount ). Otherwise, the bottom is just a pivot point, the motor isnt actually fixed to the mount as such. I think a small bearing would be better than a plastic spacer- zero slop or play in the bottom of the mount- a flanged bearing would be even better come to think of it..
