07.23.2010, 03:24 PM
Whatever is easiest for you- I would just butt-joint the 10guage wires onto those motor wires put male bullets on the other end that will plug directly into the esc. Or you could solder female bullets to the motor wires, then male bullets onto wire that goes from the esc to the motor. Whatever is easiest for you, just use decent solder and a hot iron.
Deans are rated for 65amps continuous, so they do fine in 99% of r/c applications. I use 5.5mm bullets or EC5 connectors as they are easier to grip and solder, again, whatever works best for you.
Dj_Sparky
07.25.2010, 08:13 PM
Ended up ordering 5.5mm bullets for the motor and ESC. Is that enough for the 1527 and Mamba? Rated at 150A, I figure it should be good enough, but what about bursts?
nuz69
nuz69's Avatar
07.26.2010, 05:24 AM
If its enough for the ESC input (battery), it's enough for output ;)
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Dj_Sparky
07.26.2010, 05:34 AM
Finally found some 6.5mm bullets in Norway (They were all sold out at Offshore electrics.), so that's not a problem anymore.
Thanks again for all the help. My questions may seem a little redundant, but I just want to be absolutely sure about this. First time converting is a little overwhelming.
07.27.2010, 10:41 PM
That's what we're here for
Dj_Sparky
08.01.2010, 09:53 AM
I'll start with low gearing of course, probably 30ish mph at first, starting out with a 12 tooth pinion on a 50-60 tooth spur or so (Does that sound right?)
I can't figure out exactly what speed I'll be getting on the top speed estimator sinced I don't know the diff ratios of my GST 7.7 yet, but is it safe to start with 12 tooth pinion and 60ish spur atleast?
nuz69
nuz69's Avatar
08.01.2010, 10:42 AM
Yes, use the lowest gearing possible at start. Check temps, but i think you will be able to gear up to 40mph without issue on 6S, the mamba monster can handle lot of power.
