07.26.2010, 12:24 PM
You will not find a charger that have ac/dc capability that has a built in power supply.
As for the hobbycity lipos, go to 6s, lower pinion on the flux to 17t or so and you will be find with the 30c lipos.
Freezebyte
07.26.2010, 12:28 PM
Uh, yes there is
http://dynamiterc.com/Products/Defau...ProdID=DYN4064
07.26.2010, 12:32 PM
Originally Posted by Freezebyte View Post
Whoops, need to add that you will not find a "powerful" charger that has a built in PS.
That charger you link will only do 100 watts, so 4 amps at 6s. Not powerful IMO. 2c charge rates are a must, as the minimum, so a 10amp capable charger is a min, at 6s. So that would have to be 260 watts.
Cheap chargers suck, get something decent dude. Or don't listen and get a triton and some smc lipos...
You can run the 30-40c HC lipos, I see no probs with them in general. Go to a pair of 3s packs, run them as 6s and gear down to a 15-17t pinion on that flux.
Freezebyte
07.26.2010, 01:01 PM
That one will do 8 amp charge rate and im only going to run 4S still
JThiessen
JThiessen's Avatar
07.26.2010, 01:19 PM
So the biggest packs you can buy to charge on it will be 2S 4K's. (I'm assuming that it will do two packs at the same time). Personnally, I would never purchase another Dynamite charger. I ruined more Nimh packs on Dynamite chargers than I care to think about. They may have gotten better, but I wont take a chance on them.
