Losi LST2
07.26.2010, 10:20 PM
Originally Posted by kazuaki View Post
reno911,
I bought a 5x15x5 bearing from Boca Bearing. This will replace the crap Traxxas bearing along with the adapter cone. With a few spacers, it can be made to fit with no issues. I have not had any failures with this setup. I just recently installed the new King Headz motor mount because it's cool and I'm a sucker for new parts . Lemme know if you just want to try out the 5x15x5 bearing. I probably have an extra.
how are you liking the KH motor mount?,
kazuaki
07.27.2010, 12:26 AM
So far, so good. The machining is top notch and it fits great. The new bearing is a lot beefier and they even give you two of them for that price.
Losi LST2
07.27.2010, 07:13 AM
i might look into picking one up then. does the aluminum seem like it's good quality?...i don't want to end up buying one if it's not going to hold up...kinda like some other company....cough integy cough
ta_man
07.27.2010, 08:14 AM
I think anything from King Headz is going to be far superior to anything Integy. Just being made of 7075 instead of the more typical 6061 is a plus.
Interesting thing though: I decided I wasn't going to run my 4X4 until I got a STRC aluminum mount. Having the aluminum mount, I am the only one at my track (out of 20 cars) that has had problems with the center bearing (twice: once it seized and then a second one blew up completely).
A friend of mine suggested that the heat from the motor, being conducted through the aluminum mount to the bearing, caused the bearing lube to thin and run out leading to my bearing failures. That's why I did the mod to the platic mount first. (Also, it was the first time I had ever used a boring head and I didn't want to "experiment" on a $25 mount when I could do it on a $4 mount.)
