07.27.2010, 10:41 PM
Originally Posted by Dj_Sparky View Post
Thanks again for all the help. My questions may seem a little redundant, but I just want to be absolutely sure about this. First time converting is a little overwhelming.
That's what we're here for
Dj_Sparky
08.01.2010, 09:53 AM
I'll start with low gearing of course, probably 30ish mph at first, starting out with a 12 tooth pinion on a 50-60 tooth spur or so (Does that sound right?)
I can't figure out exactly what speed I'll be getting on the top speed estimator sinced I don't know the diff ratios of my GST 7.7 yet, but is it safe to start with 12 tooth pinion and 60ish spur atleast?
nuz69
nuz69's Avatar
08.01.2010, 10:42 AM
Yes, use the lowest gearing possible at start. Check temps, but i think you will be able to gear up to 40mph without issue on 6S, the mamba monster can handle lot of power.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
