brushlesswonder
Question 07.28.2010, 08:57 PM
Brushlesswonder...
The new software is not release software -- so it isn't put into production units. It's Beta software, for people to try out and give comments.
You can always downgrade back the previous version if you are having issues with it.
Patrick
ok, i have downgraded to 1.24 software. i hope this works. is the 2200kv motor supposed to spin in steps?
crazyjr
crazyjr's Avatar
07.28.2010, 11:41 PM
Yes, there is sort of a lurch then go to it (I call it a sort of chop or detent). It is due to the design of the motor, it's similar to brushed. the wires are wound on iron cores but in the can instead of the armature shaft. I have a Neu 1515/2.5d, similar to your but wound different, and that is normal
