DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.12.2010, 07:41 AM
the run time would almost solely depend on the quality of the batteries. the higher the mah, the more runtime you'll have. the only difference in the setups from that point will be heat effeciency. the lower kv motors will be able to be geared higher and will run cooler.
the reason why i go with the higher kv motors is i've never been able to really get my motors hot. even in races, they almost never see above 160.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
FuNkY FrOg
08.12.2010, 09:17 AM
The batteries I listed are all the same make from the same site.
DwightSchrute
08.12.2010, 09:22 AM
then no setup would run longer than the other if both used the same packs. it's just a matter of effeciency of heat at that point
auto2
08.12.2010, 11:11 AM
5s 5800 will have more run time than a 4s 5800 with correct motors and gearing.
i run 5s 5000 with 1550 tekin motor. about a 15 tooth pinion ( i think)
FuNkY FrOg
08.13.2010, 06:14 AM
Do you think 776g would be too much weight?
I've used the Losi conversioin kit.
auto2
08.13.2010, 11:05 AM
deepends.... on many things. if your running 10 minute races with other electric truggys then u dont need a heavy battery. if your trying to run 30 minute races then a 5800 wont make it so u need 2 smal;ler ones to go 15 minutes each, a 20 minute race is tricky. 5800 might just make 20 so youll need it no matter what it weighs.guess i need more info on what your doing lol.
FuNkY FrOg
08.13.2010, 12:28 PM
I will be running against nitro's (Buggies & Truggies).
When i say "too heavy" I mean would it unbalance the truggy over jumps etc...
I have been trying to find out what the limit of the battery weight is with the Losi conversion kit.
I'm not 100% sure how long the races are but I think 15 minutes would be about right. I just want to make sure I can make the 15 minutes without running out of mah lol.
I have decided on the Tekin system but I really dont know what combo would be best for me...
