auto2
08.12.2010, 11:11 AM
5s 5800 will have more run time than a 4s 5800 with correct motors and gearing.
i run 5s 5000 with 1550 tekin motor. about a 15 tooth pinion ( i think)
FuNkY FrOg
08.13.2010, 06:14 AM
Do you think 776g would be too much weight?
I've used the Losi conversioin kit.
auto2
08.13.2010, 11:05 AM
deepends.... on many things. if your running 10 minute races with other electric truggys then u dont need a heavy battery. if your trying to run 30 minute races then a 5800 wont make it so u need 2 smal;ler ones to go 15 minutes each, a 20 minute race is tricky. 5800 might just make 20 so youll need it no matter what it weighs.guess i need more info on what your doing lol.
FuNkY FrOg
08.13.2010, 12:28 PM
I will be running against nitro's (Buggies & Truggies).
When i say "too heavy" I mean would it unbalance the truggy over jumps etc...
I have been trying to find out what the limit of the battery weight is with the Losi conversion kit.
I'm not 100% sure how long the races are but I think 15 minutes would be about right. I just want to make sure I can make the 15 minutes without running out of mah lol.
I have decided on the Tekin system but I really dont know what combo would be best for me...
auto2
08.13.2010, 01:36 PM
i have a 5s 5000 with the 1550 tekin and im happy with it since last summer and no problems.i have the same ttop speed as the nitros and never overheat. jumps are all normal. no issues.
