Finnster
KillaHurtz
Finnster's Avatar
08.17.2010, 04:26 PM
Man, if briang sees all those fans he's going to have a fit. lol
BMW318TI
08.17.2010, 04:30 PM
what do you mean hahah?
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.17.2010, 04:35 PM
WOW, what is up with all those fans?? Building a 150mph buggy that will run in a desert?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
BMW318TI
08.17.2010, 04:37 PM
Yup he are 100% right!
Update tomorrow!!!
Also ordered these stuff.
MMM2200KV (will use as spare) and Hyperion EX 4200 mAH 45C
2650KV on 6S and highest gearing hahaha hmmm..
snellemin
2 KiloWatt RACER
snellemin's Avatar
08.17.2010, 05:28 PM
Ahh, so a Dakar style buggy?
brian015
brian015's Avatar
08.17.2010, 08:12 PM
Ever consider water cooling?
http://www.tcscooling.com/index.html
nitrostarter
nitrostarter's Avatar
08.17.2010, 10:19 PM
Holy cooling fan batman! Thats overkill on the fans!
N. Rustler conversion
BMW318TI
08.18.2010, 04:32 AM
Thanks hmmm looks very good!!!
Never
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Never - 08.18.2010, 05:43 AM
I have never seen that many fans on one R/C vehicle. Considering that allot of guys run the CC MMM without a fan I think you are a bit overkill there. Six fans on one car is totally not needed. You could have installed an A/C unit and used less power, and dropped a few ounces in weight.
Why so many fans? All you really need is one on the ESC and one on the motor. Your losing half of your battery power on those fans, which will cut your run times by 30%. That thing will run in hell and not over heat.
You do nice work by the way. Your setup is clean and very neat. Great job.
SUPERMAXX YOUR LIFE.
BMW318TI
08.18.2010, 06:07 AM
Nope fans has their own power supply and CC Bec pro hahaha:-).
O well MMM can easily handle the extra weight it's 120A motor hahaha.
Also the fans don't weight that much:-).
Dreams
JERRY2KONE
JERRY2KONE's Avatar
Dreams - 08.18.2010, 06:17 AM
Everyone has their own dream of what the perfect R/C vehicle is supposed to look like. I guess your dream is one with lots of fans? To each his own.
BMW318TI
08.18.2010, 06:25 AM
Yes I love to push the stuff to maximum.
I don't like playing safe hahaha.
And the temp. is about 116F with current setup.
Temp. is measured with Spektrum Telemetry temp. sensor.
08.18.2010, 02:23 PM
You shouldnt have cut the sides off the motor fan mount- it is designed to funnel air down around the motor and between the fins to ensure maximum cooling & heat exchange- without the sides, the air is just blowing against that one spot under the fan and then dispersing..
BMW318TI
08.18.2010, 03:42 PM
Yeah I know, but the little fan sucks.
That's reason why I have 3D cooling hahaha
Question does the watercooling really helps a lot?
brian015
brian015's Avatar
08.18.2010, 04:43 PM
Turn it around.
