mwe-maxxowner
mwe-maxxowner's Avatar
08.22.2010, 11:59 AM
16.8 v emaxx long chassis. It wasent brushless when i purchased it. I put the mmm on it. The mmm came with an 18tooth pinion gear and i thing the emaxx came with a 62 tooth spur gear.
Brushless-taking back rc!
E-revo is DONE!
  Send a message via AIM to mwe-maxxowner
redshift
RC-Monster Square Tube
redshift's Avatar
08.22.2010, 12:05 PM
That's the same as stock gearing with the Titans IIRC, that's gonna be way high. Probably something like 14/66 or 14/68 will be much closer. But then again if you're looking to do 65+mph then make sure you do short runs, like under a minute and keep a very close eye on temps. But do check BrianG's calc for precise speed first.
redshift
redshift's Avatar
08.22.2010, 12:07 PM
That's the same as stock gearing with the Titans IIRC, that's gonna be way high. Probably something like 14/66 or 14/68 will be much closer. But then again if you're looking to do 65+mph then make sure you do short runs, like under a minute and keep a very close eye on temps. But do check BrianG's calc for precise speed first. It is stickied at the top of the Brushless forum, click back once and you're there...
