08.24.2010, 01:59 PM
No you are getting completely mixed up on ratings and capacities...
a 20c 5k pack should support 100amps continuous - About the minimum recommended batteries - ideally you'd be at 125amps for a 4S setup.
The fact that you are only putting 2500mah back into each pack is a little worrying...
Pictures of everything would be helpful
thzero
08.24.2010, 02:13 PM
Even the 25C 5200MaH are barely over that min. recommended 125amps.
[QUOTE=Arct1k;377890]a 20c 5k pack should support 100amps continuous - About the minimum recommended batteries - ideally you'd be at 125amps for a 4S setup.
Also what gearbox and which internal gears you are using, which diffs, what tires, etc.
