Shorted a lipo
emaxx 101
Shorted a lipo - 09.02.2010, 12:45 AM
Hey guys, just got my hyperion 3 cell g3 vx packs. When I was soldering one of the traxxas connectors on the leads accidentaly touched...twice. There were sparks but just for a moment each time. Put them on my charger and the pack still had the same voltage as the one that hadn't been shorted. Am I ok?
scarletboa
scarletboa's Avatar
09.02.2010, 01:24 AM
you should be fine. i did the same exact thing when i soldered up an old zippy battery. as long as the cells aren't swollen and the voltages all check out, you are fine.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
09.02.2010, 09:38 PM
You'll be fine, just keep an eye on it. I shorted 2 of my 6 lipos for my bike before I got andersons on. One short was bad enough to burn a battery tab; I resoldered it. The shorted packs show a little damage, but they work fine. They are 6s packs and the damaged ones have a somewhat-weak cell or two.
emaxx 101
09.03.2010, 12:36 AM
Thanks guys! Charged them up and wow... those hyperions are double the power than my true rc's. No puffing from the batteries Off topic question... I put some badlands on lpr sized rims and after the run, the wheels seemed to be much larger in diameter and thiner. When I press on the tire I can feel air inside... so I am assuming that air somehow got trapped in there. I did not drill holes in the rims for air, could this be the problem?
simplechamp
simplechamp's Avatar
09.03.2010, 11:33 AM
If they are sealed then the air inside may have heated up and expanded? but if that was the case it would go back down after cooling off... You can still drill holes in the wheel/tire, just be careful that the foams don't get mangled by the drill bit
DCastaneda
Speed Addict
DCastaneda's Avatar
09.03.2010, 01:06 PM
Just use a body reamer to make two small vent holes on the middle/outside of the tire.
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
emaxx 101
09.03.2010, 01:40 PM
I went ahead and drilled two holes in each tire this morning, and what do you know, the tires realesed all their air and returned to normal size. Thanks again guys!
