brushlessboy16
brushlessboy16's Avatar
09.15.2010, 07:34 PM
Your going to end up spending hundreds of dollars diagnosing a phantom problem when you can spend 20 on a temp gun
there have been times where i have felt my motor and could have sworn it was cooked, but then the temp gun says 160, which aint bad.
Just get the temp gun....
Muggydude
09.15.2010, 07:41 PM
Well to put in some input. I have sealed the motor like Freeze did, running 20/44T with the same exact 2s lipos (Turnigy 5200mah 30c). I also have the heavy-ish TCS 5mm chassis, but i am running on Masher MT tires whith RPM stablemaxx wheels (Smaller than stock tires). Anyways, my motor has stayed pretty cool, hottest right around 120F. The ESC has runa little hotter, as the fan will intermitently come one and off during the run for about 45 seconds. So it should be around 145F throughout the run. Not sure exactly what to say, as the ony difference in our setups are tires and chassis.
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
