Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
itbvolks
09.21.2010, 09:00 AM
The Delrin spur gears hold up exceptionally well - only extremely excessive amounts of slip will cause enough heat to create a problem. we did pretty extensive testing before releasing the Delrin gears. As with any plastic spur, the margin for error is reduced(if you get a loose gear mesh, the plastic spur is the weakest link) - when gear mesh is properly maintained, the cnc'd Delrin gears have a very high load capacity. Tthey are wisper quiet as well.
Regarding the runout - while nothing is perfect, the Slipperential assembly should run pretty concentric. Some possible causes of excessive runout(if this is indeed the case) would be the spring orientation(must avoid stacking the "overlaps" on the springs), or a worn or improperly seated Teflon bushing.
Mike,
What I think happens on my unit is, when the tension collar is locked down, it actually distorts the alum back plate some. I think it's just a function of my locked down position. Like I said, I'm just looking for some driveline protection so the unit itself is locked down pretty good. With the overlap on the wave springs, I think they pinch some causing the distortion.
Overall, I wouldn't say it's an issue per say. I've been running this since the basic release of the slipperential without issue so clearly it's not causing that much of an issue. On my second pinion.
I do like the idea of reduced driveline mass though. Provided the delrin verison isn't prone to failing. I'm not too worried about mesh issues being the motor/diff is on the same plane so provided the motor doesn't physically move in the mount, it should be fine.
Sounds like the delrin would be/is viable in my application then. Nearly no slip. I temp the diff in the low 100's temp wise (assuming heat soak from the motor). So shouldn't melt. lol
