reno911
Smelly Nitro meet your maker!
reno911's Avatar
09.22.2010, 11:21 AM
Okay so the neg side looks pretty bad, though the cells themselves, at least, look to have been soldered well. The balance tabs not so much, cold joints for sure. i would just get the iron out and heat them all together.
I searched my image hosting and I thought I had a pic of one. I have a zippy open at home I will surely take a picture of it when I get off.
How much currant travel through the balance tabs anyway? Shouldn't you really be worried about the leads, which both look to be well soldered.
pinkpanda3310
pinkpanda3310's Avatar
09.22.2010, 12:17 PM
My current 35c hyperion lipos are extremely powerful.. .they outperform any 35c lipo i have tested from hobbyking so far, including some expensive lipos i bought here in the UK from a reputable seller which cost me just as much as my hyperions (problem is, hyperion lipos are crap in terms of their soldering!!!)
So your hyperions out perform anything you have even with dodgy solder.....
yes they definitely will!!! (i actually believe they would be too much in terms of punch causing everything to fall apart haha...
....and you would rather rip apart your car with higher voltage than higher c rating? I understand you why you are worried about heat issues with higher c and dodgy solder but it sounds like you have little faith in hyperion when the quick and easy fix would be...
I don't know what charger you use but if money is tight then you don't want to be getting batteries and charger to suit.
