09.22.2010, 06:24 PM
Whats the C rating on MA packs? Any noticeable difference in temps between the HK and MA lipos at the end of the runs?
I'd be inclined to do a little testing myself- discharge both packs down to 3.0-3.2v per cell or whatever your charge allows, note mah capacity removed if it displays that info, then do a normal 1c charge and compare the mah put back in again.
All things considered, it seems like the mah capacities are over and underrated perhaps?..
