Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.23.2010, 02:51 PM
Vehicle Weight (lbs): 6.4
Vehicle Width (in): 12.0
Vehicle Height (in): 6.0
Pinion Tooth Count: 20
Spur Tooth Count: 50
Transmission Ratio: 1
Differential Ratio: 2.8461538461538462
Other Ratio: 1
Tire Diameter (inches): 3.85
Tire Ballooning (in): 0
Drag Coefficient: 0.35
Total Voltage: 11.1
Electrical Efficiency: 85
Target Top Speed (mph): 32
Time to Get to Top Speed: 1.5
Usable Output Power: 425.15 watts (0.57 HP)
Input Power Required: 666.9 watts (0.89 HP)
Input Current Required: 60.08 amps
Motor Torque: 0.24 ft-lbs
Axle Torque: 1.68 ft-lbs
Average Acceleration: 9.54 inches/sec
Acceleration Force: 27.68 meters/sec^2
Acceleration Gs: 0.97 G
Required Motor RPM: 19879 rpm
Required Motor KV: 1791
KT constant: 0.76 oz-in/A
