Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
tedo
Vermont, USA
tedo's Avatar
09.24.2010, 08:54 AM
Did you assemble it with the pressure all the way loose?
Ah, I bet that's it!
I did not change the tension on the wave washers... I bet it it was all the way loose, then the side with the spur would get closer towards the diff cup to get the mesh right, then I would just re-tighten the slipper again. doh.
Thanks for the heads up.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.24.2010, 07:18 PM
The best way is to assemble the slipper side first, install the slipper/spur and tighten, then install the other side of the diff. That way you know the slipper side is properly aligned, and the other side of the diff isn't affected by the slipper tension so it's easy to screw on.
tedo
Vermont, USA
tedo's Avatar
09.25.2010, 03:58 PM
Yup, totally worked now. I just needed to loosen the collar on the wave springs. Cleaned up, and fresh diff fluid. Retightened the slipper and now she is whisper quiet.
Thanks for the advice guys.
4x4 Pede
