Bmr4life
09.29.2010, 04:05 PM
Originally Posted by finnster View Post
i don't that word means what you think it means
then again, looking at some other threads, maybe you do.
lmao
Freezebyte
10.20.2010, 09:15 PM
Well after considerable thinking and weighing of options, i've decided to go back to stock savage size for FB2 for a couple of reasons
1. 6s lipo barely controllable, even with XL mods. Likely to be even worse with standard size Savage frame.
2. 4s plenty of power to move around stock savage size and still have wheelies, backflips and all the fun power without the added strain and wear on components vs 6s usage
3. More and tougher body options
4. Compact and smaller frame and sizeis more bashable and less likely to get damaged
5. 4s usage gives motor and ESC headroom vs 6s, so there less likely to overheat under extended use
That said, i've sold most of the XL stuff to make up in costs. I went ahead and deanodized the stock TVP chassis to give a new lease on life until I see a reason to upgrade to a thicker frame, likely from Team TCS next spring. I also managed to recycle the stock body to fit on the standard savage from. A little trimming here in there and doesn't look half bad! I didn't realize how much I liked and missed the standard "Monster truck" look the Savage. After a $65 repair bill in 6s lipo usage damage, I'll stay with 4s power and go back to stock 20/44 gearing for the best balance of power/speed.
Needless to say, next spring i've some new ideas for FB2. But until then, she'll stay this way for the last days of bashing in 2010!
Freezebyte
10.22.2010, 02:22 PM
Just got done doing a nice bash session with jumps, sand pits, high speed runs and general screwing around and im very pleased with the results of going back to 4S on standard Savage chassis. The truck isn't quit as "stable" as the XL for obvious reasons but beyond thats, its just more entertaining to drive. It now looks, feels and acts like a monster truck, powering over everything in its way. 4S is more then enough authority to get it moving, even with 80% punch control, it I can still do wheelies and mid air control easy. I didn't hear the ESC van kick on once and the motor stayed below 110f the entire time. The speed is "just right" when the tires start to balloon at max throttle, its borderline controllable but no where near as bad as 6s was. The truck jumps and lands well and because its more "compact" vs the XL conversion, it recovers easier from bad landings and crashes. Nothing broke either, bonus!
I finally found the balance of fun, performance and reliability that I wanted outa my Savage! Next spring i'll be go back to 20t pinion, order more 4s lipos, paint a new body and possibly a TCS chassis and deanodize the color. Beyond that, im happy as peach!
Freezebyte
10.23.2010, 05:56 PM
Just a few pics of FB2 at regular Savage size screwing around the truck today. I'm amazed at the handling difference between stock and XL, two different trucks entirely! I think my stupid Tork motor is still twisting in the damn motor mounts so I gotta figure out a way to stop that somehow as im sick of having to em take out, clean screws, re loctite and rescrew them in.
josh9mille
josh9mille's Avatar
10.23.2010, 06:17 PM
Try filing down the tubes that the screws go through, it should make it so you can get some more squeeze in the motor
Freezebyte
10.23.2010, 09:45 PM
Hmm, thats a thought
JThiessen
JThiessen's Avatar
10.24.2010, 02:40 PM
When you say twisting - are you meaning rotating? Or are you still seeing forward-aft movement of the motor?
Freezebyte
10.24.2010, 03:01 PM
Zips took care of forward movement but now its rotating
