Freezebyte
10.01.2010, 08:08 PM
I'll run it again tomorroo at bash pit with 10% punch control and see what that does.
Not sure if I wanna spend the money on 6s lipos when its getting so close to winter and the Flux will be shelved.
_dV
10.01.2010, 09:10 PM
So it seems the temps are ok but i guess having lower temps would allow running in higher ambient temps and prolong the life of the electrics a bit.
If your not overly interested in trying to understand the causes then just buying a larger spur and or smaller pinions to try would be way to go. Gearing down further should cover most things assuming nothing is actually wrong.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
10.01.2010, 11:15 PM
Such a shame. A winter themed Savage that sits throughout the winter.
Freezebyte
10.02.2010, 01:00 AM
I know but I just can't afford *literally* the electronics to get smoked in the snow and lipos don't like cold weather either
reno911
reno911's Avatar
10.02.2010, 02:57 PM
Just follow some simple waterproofing techniques and your Savage should be fine. Lipos don't mind the cold the correct way to store them is in a fridge. While running they do appreciate being warm though. So if starting from room temp and through discharge they should be able to keep themselves warm enough to melt any snow that manages to get inside the battery trays.
Some good things come from running in snow, no heat problems, in fact I usually gear up during the winter because the temps allow it. Snow for the most part is fairly clean so clean up is a breeze. As long as you spray a little wd40 on some spots after running nothing should go bad.
As for the plastics getting weaker, think about the material in which you will are bashing in. Snow is a little more forgiving than concrete or hard pack.
Freezebyte
10.02.2010, 04:09 PM
I just simply don't wanna take the risk with the Flux. I"ll get a Slash 4x4 if I really wanna go bashing in the snow.
Soro
Flux Fan
Soro's Avatar
10.03.2010, 01:33 PM
Brushless motors are incredible pieces of engineering, its amazing how little we have to maintain these things compared to brushed motors. To help extend the life of my new Flux Tork motor as well as reduce maintenance intervals, I'm gonna seal up the front endbells openings with some set screws. I asked Patrick del Castillo, president and principle Engineer of Castle Creations at the RCM forums about doing this last year. He stated that there should be no issues with sealing the endbell of the 2200kv motor up. Never hurts to double check when your dealing with a $200+ motor and asking the president of the company who designed the motor is about as good as you can get! Major Kudo's to Castle Creations for their help and support at RCM in dealing with customers questions and issues on a face to face basis.
I would ask them again
Savage Flux 5mm TCS TVP with 8 Big bore shock conversion : Savage Flux XL TCS TVP with 4 IRC shock conversion
Freezebyte
10.03.2010, 03:21 PM
I asked Patrick last year as well about the endbell sealing and he said their shouldn't be any concerns.
