ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
10.07.2010, 03:48 PM
Looks GREAT! Those are some very nice shots you've taken.
About that Racer's Edge servo arm. Can you tell me if the linkage hole is tapped for a 3mm Screw or 2.5mm?
Also, How does the Locking spindle part work out, does it clamp around the Spindle and Also use the standard screw to hold it on the servo ??? 4 total screws? Thank you, Sir.
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
10.07.2010, 04:39 PM
Hey Zippy, thanks man... the servo arm uses a 3mm for the spindle hole... most of the holding force is created by the two tiny screws that are mounted through the sides of the clamp...
I used the M3 screw to push the arm down over the spindle because the initial fit is a little tight... If you want additional holding power from the M3 screw, you will need to shim the inside of
the spindle hole... the linkage hole is 3mm and you will be using a total of 4 screws...
see the link below:
Clamping servo arm
Alien
Popoxx
Sapere aude
Popoxx's Avatar
10.09.2010, 04:34 PM
Pics and car : work of art !
Protek lipos are great I really like mine you won't be disappointed !
ANGRY-ALIEN
10.09.2010, 07:36 PM
Thanks Popoxx ... yeah, these lipos sure pack some punch... it's been raining here for a couple weeks, so no test runs on the track..
I did some runs on the carpet at office a couple days ago and it was whole lot of fun.. i'll make an update as soon as get the car on track.
Alien
Tags
lrp sphere, x12, xray t1, xray t1 evo2
