Jahay
09.06.2010, 04:40 AM
loc tite does not work with plastic diff cups.. if you can and its available, you should try and run the alloy diff cup! will allow no flex within the cup, and loctite will actually work
pinkpanda3310
pinkpanda3310's Avatar
09.06.2010, 04:51 AM
That's what I was thinking, thanks Jahay.
Klausen
Brushless G-maxx
Klausen's Avatar
10.09.2010, 01:38 AM
Will the 1520 fit in a Revo 3,3 with Mikes motormount?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.09.2010, 10:02 AM
I dont think so, When I had mine the 1515 was close to the arms and the 1520 is a mile longer.
Ok
Klausen
Brushless G-maxx
Klausen's Avatar
Ok - 10.09.2010, 10:43 AM
I will throw it in the Gorilla then.
Will it be ok to run with a Tekin RX8 or Novak HV esc? I now it is not sensored, but without the sensorcabel?
Or do I need a MMM esc.
10.09.2010, 11:15 AM
Go for the RX8 rather than the HV... No need to get a MMM if you hve have an RX8 handy
Klausen
Brushless G-maxx
Klausen's Avatar
10.09.2010, 01:18 PM
Perfect thanks.
Emaxx_Quebec
Emaxx_Quebec's Avatar
10.22.2010, 01:08 PM
Is there a possible mistake with the KV written ON the motor?
My order came in today and I notice that the 1520 is quoted 1600 kv on the box and 1520 1y 1500kv ON the motor
I am alone with this situation?
Fred
nuz69
nuz69's Avatar
10.22.2010, 03:21 PM
No you are not, a friend of mine had the case, but castle glue a sticker on the box saying it's an mistake, the motor is a 1600Kv, so don't worry ;)
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
bruce750i
bruce750i's Avatar
10.22.2010, 03:49 PM
yep I got one also, I call it my custom wound 1520.
Emaxx_Quebec
10.22.2010, 03:50 PM
Nice then.
Thganks a lot
Fred
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.05.2010, 08:08 PM
I finally used the 1520. Stuck it in the TM buggy on 4s and Qaurk esc. Works pretty good.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
11.06.2010, 02:05 AM
... wow... do you think you have enough power for your buggy now?
nuz69
nuz69's Avatar
11.06.2010, 04:27 AM
I use a 1520/1Y on 4S in my buggy since a while now. I have better runtimes than my previous 1515/1Y, but it add 59 gramms
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.06.2010, 07:10 AM
I agree that it runs cooler then with the Pletty. It accelerates harder then the 1512 1400kv motor that I have. The weight is killer though, but I figured I stuck a V8 in Civic and have to drive different. Gearing is 46/23 and I'm waiting for Mike to get his 26T back in stock.
