feistyacorn
feistyacorn's Avatar
10.11.2010, 10:34 AM
Originally Posted by SavageCanadian View Post
Does the Slipperential really make that much of a difference?
It's really a nice tuning option and it helps save the entire drive system. I run one in my XT8 and Gorillamaxx. Just make sure you get the real deal from RC-Monster and not the cheap fake one.
SavageCanadian
SavageCanadian's Avatar
10.16.2010, 06:55 PM
Well I took it out for its first test run today and it did really well. The chassis flies nice and neutral. Im defiantly impressed and I have yet to put it on the setup station. I can defiantly see were the slipperental would be nice to help smooth out the power. I will have to pick on up over the winter for next year.
Xray XT8-E '09 Spec - Tekin RX8/ 2250/ RCM Conversion/ Gens Ace 4s 5000 40c
  Send a message via MSN to SavageCanadian
SavageCanadian
03.05.2011, 03:56 PM
Just ordered the slipperential finally, anything setup wise with it I should know?
feistyacorn
03.07.2011, 11:58 AM
I guess it probably depends on what the track condition is like. I am running 5k-7k-3k for diff oil in my setup (similar to yours). Did you get the steel gear or the delrin gear?
SavageCanadian
03.07.2011, 05:23 PM
I got a 50t delrin one, the steel is so noisy that I thought it might help, and I have had good luck with plastic spurs when I had my 4x4 SC. I think I will probably put either 7 or 10k in it and go from there,
feistyacorn
03.07.2011, 05:32 PM
Cool! It will be interesting to hear your results. I was thinking that I would give the delrin a try sometime. What is loud for brushless doesn’t compare to nitro.
SavageCanadian
03.08.2011, 10:49 PM
True but the sound of a nitro engine sounds way better then 2 noisy gears going by on the straight.
Smashwings
Smashwings's Avatar
03.11.2011, 08:26 AM
Hi, the delrin one you picked is for the slipperential or for the stoch differential? because I'm sarching for a compatible Spur for stock differential. Kyosho ones do not exactly direct fit, and I don't want to have silicone leakage.
Have heard about AE ones
Anyone knows?
Thanks
SavageCanadian
03.11.2011, 08:13 PM
I am replacing the center diff with a slipperential, as far as I know AE plastic spurs will fit the xray diffs, you just need the ae orings for the spur as well.
SavageCanadian
03.29.2011, 02:25 PM
Pics
feistyacorn
03.29.2011, 02:39 PM
Looks great! Hows that delrin gear working? Silent?
