_dV
10.22.2010, 08:17 PM
I'm having a bit of down time atm with the truck due to a freak accident so I thought I would post up comments about how some aspects of this build have worked out in practice. I have about 15 full runs up on the truck in various environments including:- an offroad track, grassy parks, various dirt offroad locations and a couple of skate parks.
Comments are based on a running setup of:-
- 52t mod1 spur, 11t pinion. (total reduction ratio 15.2, max speed 41.26 mph (66.28 km/h))
- 500K slipper fluid, 50K front\rear diff fluid
- Turnigy 6S 5000mAh 30C Lipo
- Tekin T8 Truggy 1550kV, RX8 with 2.08 software
Shocks Tower Supports
Really wasn't sure how these would go. I was concerned they would make the towers too stiff and cause damage on impact. Was also anxious about how it would affect the suspension. Turns out that so far they are a highlight of the build for me.The tie rods pivots allow the tower to flex a bit in a few directions while preventing the whole tower from bending backwards. The tie rod ends also have a little flex in them. This seems to allow impacts to be absorbed ok. As an added bonus the top shock mount bolts don't bend anymore. These would usually bend after a few runs. I've had some pretty decent crashes and they looked ok. I wasn't convinced so i took one front and one rear out this morning and they were still perfectly straight.
On the suspension side of this I have had to dial back the shocks from what I thought I would need. The supports really make a difference to how a stiff a suspension setting feels. Handling feels sharper to me and
the truck appears to handle landings from height better.
I have been considering moving the receiver in behind the front shock tower to tidy things up a bit now that i have confidence in the supports.
Battery\Motor\ESC
Runtime is 30-50 mins depending on how I drive. For bashing its usually towards the latter.
Temps, running in mostly 22-25c ambient, motor temp max I have seen is 54c which is great. ESC fan comes on for short periods, temp on it is usually around 34c, battery mostly reads 32c. Happy with the temps atm, will see how they go in the Australian summer.
There were 2 things that annoyed me with the ESC. They were the braking strength and the long'ish delay time for the reverse but both of these have been fixed with the 2.08 software.
Custom Chassis
The 5083 H321 grade Al has held up well. Don't think it is as hard as the 6061 but it does the job. It's very stiff when all bolted up.
The chassis was center balanced when i was running 5S. The 6S battery is 93 gm heavier but the rear end of the truck handles better now so it seems a little weight towards the back is better for this build.
Motor Mounting
Had my doubts about the Tekno mount and if it was suitable. I thought the mounting bolts might slip being bolted on the side of the TVPs but this hasn't happened once. I wasn't too keen on only bolting the motor at the front to the mount but i was able to use M4 bolts and the motor fits snugly in the mount, no probs thus far. It seems well supported.
Maintenance
Truck is night and day to work on compared to a stock Flux. I haven't had to remove the TVPs since the final assembly. With the exception of having to remove the skidplate first, any component inside the TVPs can be removed by undoing the bolts that are easily accessible from the outside of the TVPs and then just pulling it out. Gear mesh is a breeze to adjust. I assembled\disassembled the truck a lot during the build and its much quicker than the stock Flux, no real fiddly bits or stuff you have to do in the right order etc.
MDF Skidplate
Holding up ok, definitely need one at skate parks. It's getting beatup a bit quicker than I thought. If I can find some 3 mm plastic\acrylic sheet I might try that at some point.
The grinding on the sides happens at skate parks. Yes that is part of the RX8 you can see, did i mention freak accident?
Steering
Have had no issues with the reversing of the steering link. Hitec 7955TG + bearings + FLM drag link + hellfire tie rods + HD servo saver spring has resulted in a strong and responsive steering setup. I was considering purchasing an all Al steering replacement before but not now.
I wouldn't mind a slightly better turning circle. Might try the RSC kit or grinding existing parts at some stage.
Wheels
Stock Flux tires on inner bead of Rulux half offset halfups. The half offset works well with the lower profile, no probs with the truck wanting to roll over sideways a lot. Grip seems a bit better in some situations than the stock tires on normal sized wheel but worse in others. I like the diameter\weight of these tires but not the grip so I will be trying something else. On the plus side of less grip, on a loose flat surface I can hold a pretty good power drift with them and that's quite fun
Air Control
Not quite as responsive as stock length chassis but good enough. No probs at all getting it to land on all fours. I suspect this is due to the low weight. Running weight with 6S is still under stock Flux with 4S. On the outing of the accident I did my first few backflips off a short curved ramp at a skate park. Ramp was only a couple of feet high and I wasn't getting that much air but it was enough to get the backflip out. Keen to try for a double now on a larger ramp
Diff Fluid
50K front\rear, provides for nice turning circle but feels a bit light in loose offroad conditions. Somewhere in between 50K and 100K would be nice to try though I might have to mix it up myself.
500K center diff, this gives a similar feel to the stock flux direct front\back drive but not as sharp. It was interesting to play with but I have no real interest in using the center diff to keep the front wheels on the ground. I'd rather have the sharp 4WD response and use throttle control. I might experiment with Ofna diff lock fluid or a different center diff with a locker inside to see how that feels. Pretty happy with how it is atm though and I can hold long wheelies without too much trouble.
Post is already way too long, maybe some more later. Having run the truck a fair bit I now have a heap of ideas for tweaks\improvements. Looking forward to trying them out.
