_dV
10.23.2010, 07:43 AM
mmm shiny, much nicer than the purple.
How thick are the carbon fibre TVPs? Must be around twice as thick as stock looking at the weight. I expected them to be lighter.
Originally Posted by LiqrSicc View Post
The upper arm was binding with bulkhead so I had to grind part of it:
In my instructions for the kit it says to remove a bit of that part anyway (which is part of the shock tower).
Apparently the bolts in the c hub come loose a bit. You could fix via this method. Image courtesy Jahay
