DrKnow65
DrKnow65's Avatar
01.19.2011, 02:53 PM
Patrick, sent you a PM. Going to call tech support in a few when they are done with lunch :-)
rabosi
01.19.2011, 03:01 PM
Not for anything but isn't it a good idea to not open up ESCs when they fail under warranty so that CC engineers can do a proper analysis?
DrKnow65
DrKnow65's Avatar
01.19.2011, 03:05 PM
Rabosi, the case fell off when it burnt up. I think it's only held together with thermal adhesive which gets real soft at a bizillion degrees :-)
rabosi
01.19.2011, 06:41 PM
You mentioned peeling back a plastic cover so I thought you were digging a little deeper. I wasn't trying to be critical though. Just a thought that it may be advantageous for troubleshooting purposes for the user to not open up the dead unit while under warranty. I have seen several cases where the ESCs were opened up after failure especially when the MMM first came out.
DrKnow65
DrKnow65's Avatar
01.19.2011, 07:22 PM
Well, I talked with Greg in the tech department. Generally a nice guy and was realy interested in how exactly I pulled off fitting the XL in a hyper 7 :-) and after clearing that up I probed about if there was anything else to look at on the buggy side, basically nothing (and even less) than what we've already covered here...
So I'll pack it up tonight and get it sent out to Castle for evaluation. Should be interesting to see what they come up with.
Cody.McP
01.20.2011, 02:58 AM
Well unfortunately I'm having issues with my Mamba XL now too. It won't arm. :/ Have to troubleshoot it tomorrow when I have time.. hopefully it's just a solder joint. Curse you DrKnow! You jinxed us all!
Btw, 8s + CC XL combo + Baja = Too fast for it's own good.
DrKnow65
DrKnow65's Avatar
01.20.2011, 10:21 AM
Mine should get to Castle Saturday/Monday so we can find out what went wrong after a week or so... I'm hoping
Cody, not arming was the first "odd" thing my XL did, you may just want to sent it in as well
if you don't see any really obvious solder joint, radio problem, bad servo, bad connector, ect.
Mine did arm again after cycling the power, but it only went 20 feet plus 2 more before it was in flames.
I've went over my rig with a fine tooth comb and haven't found any issues.
I'm going to double check the resistance in my 1518 at work today,
forgot to bring home my meter trying to get my XL shipped out last night.
P.s. sorry for the jinx, I was actually hoping I was just unlucky
but having another person that's having issues really concerns me.
Please consider sending it in, or at least benching it until we have an answer on mine,
it could be that yours is in the first stage of whatever lead to the death of mine.
Cody.McP
01.20.2011, 01:22 PM
Hmm, well I think I will take it out of the car and troubleshoot it from there so if anything does go wrong it won't start a fire. Hopefully it just got shook up and isn't dead, I don't want this to turn into another MMM V1
I'll keep you guys posted, have to wait till later today to test it out.
DrKnow65
DrKnow65's Avatar
01.20.2011, 09:28 PM
Just checked my tracking info, XL should be at Castle Monday before 4:30pm.
Edit: Kinda bummed they didn't offer to ship me a replacement right away
Kirkinsb
Brushless All The Way!
Kirkinsb's Avatar
01.20.2011, 11:36 PM
Got my XL, 2028 Motor & Castle Baja Conversion Kit all hooked up and calibrated...Two brand new Hyperion G3 35-65c 5500mah 4s Lipos to equal 8s. Ready to go...just need some snow to melt... Spoke with Castle Tech and the told me how to set the Torque limiter setting. Should be good to go!
DrKnow65
DrKnow65's Avatar
01.21.2011, 10:56 PM
Cody, any word on your bench testing?
padrino
hmmm...
01.21.2011, 11:13 PM
Working on finishing my install tonight, had to make a couple of mods to the mount to support things but it's looking good.
As suggested earlier in the thread I'm pressing forward with 6.5mm bullets for the batteries. I'm not as comfortable using bullets as hosed connectors due to the risk of a short so I wanted to ask those that use them what recommendations, if any they have? I'm obviously going to shrink wrap the bullets themselves but wanted to see if anyone had other pointers.
Knez
Knez's Avatar
01.23.2011, 06:38 PM
U can shorten the wire with male bullets for like 2cm or so. The risk will be a lot smaller.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
padrino
hmmm...
01.23.2011, 07:44 PM
Thanks for all of the pointers on how to lessen risk with bullets, it confirmed a couple of ideas I had. In the end I went all female on the batteries. I made my first run on 8S today and it drives just as quick as my Neu 1515 MMM powered E-Revo. I can't believe how fast it jumps around, even with all of the aluminum I have on the truck, if anything it's keeping the front end down some so maybe it's better that way.
What a great kit, compliments to Castle and the strong engineering talent it took to bring this to market.
I want to specifically thank Christy at Castle, she went above and beyond to get the kit out to me last week, my hat is off to her.
Cody.McP
01.22.2011, 03:42 AM
Hi, no I haven't yet sorry, I should be able to find some time tomorrow or Sunday though.
