kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
11.02.2010, 12:37 AM
What were you running before with the 2200kv?
I would just play with BrianG's calc to find the same end results. This motor will definitely handle it.
i had 14t 46s with the 2200 in my mugen. i was expecting bigger pinion but after using the calc it recommends 12t.
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
nuz69
nuz69's Avatar
11.02.2010, 02:48 AM
Geared for the same speed at the same voltage the 1518 will run more efficient than the 1515, so there is no problem using it on 4S, whatever its sweet spot is.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
