One pin
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
One pin - 11.12.2010, 09:05 AM
Originally Posted by Daleyb93 View Post
Ok great to know. So i pretty much have a turbocharged stock truck (allu bulks etc…) without the setscrew thingo will 8 ejector pins be fine to fit 1 truck?
Thank you
You can probably do all four corners with one 14" pin, but for the price I would get a few pins so you have back up spares. They are easy to cut with a Dremal tool using a cutoff wheel. I usually grind a divit into the pins where teh setscrews seat, and then you are good to go.
SUPERMAXX YOUR LIFE.
Daleyb93
11.13.2010, 06:44 PM
I just want to know if you know what is better between the straight ejector pins and the through hardened straight pins :O
THANKS~
Through hardened.
JERRY2KONE
JERRY2KONE's Avatar
Through hardened. - 11.13.2010, 08:39 PM
Most who are using them are getting the through hardened pins. The reason for using these over lets say the Lunsford titanium pins is that they are hardened steel and do not bend. Removing bent pins can be a real PITA. They hold up much better with little wear, and I have yet to hear about anyone breaking them. There is a thread in here some place about them, along with a link to the site where you can order them.
Here they are. http://www.plastixs.com/ep03.html
