Castle 5th scale
Rating:
crazyjr
11.16.2010, 03:43 PM
Patrick, Will it be opto or will it have a BEC? I believe last time it was said it was going to be opto. Thanks
crazyjr
Find all posts by crazyjr
2
Pdelcast
11.16.2010, 03:45 PM
Originally Posted by
crazyjr
The 8S controller has a switching 5A BEC (with programmable output voltage,) the 12S controller is opto.
Thanx!
Patrick del Castillo
President, Principle Engineer
Pdelcast
Find all posts by Pdelcast
3
Finnster
KillaHurtz
11.16.2010, 05:16 PM
Specs from the pdf PdC linked:
Length:3.94” (100mm)
Width:2.04” (52mm)
Height":1.2” (30.6mm)
Weight:4.56 oz* (129.4g*)
Max amps:200 amps**
5 amp BEC
Max volts:34 volts (8s LiPo/22 cells NiCad/NiMh)
Thanks
Finnster
Find all posts by Finnster
4
NickRummy
11.16.2010, 05:51 PM
Patrick,
Do you now if the conversion kit will include a pinion and if so, what tooth count?
NickRummy
Find all posts by NickRummy
5
Pdelcast
11.16.2010, 05:57 PM
NickRummy
Patrick,
Yes I do know that.
It will include a pinion -- 14 tooth. We will have option pinions of 12tooth, 16tooth and 18tooth.
Thanx!
Patrick
Pdelcast
6
crazyjr
11.17.2010, 04:59 AM
Pdelcast
Thanx!
Thank you, last i knew i thought they would be opto coupled
crazyjr
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
