Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Finnster
KillaHurtz
Finnster's Avatar
11.20.2010, 01:21 AM
Also recieved my mbx6t rear suspension set yesterday also, as well as all the axles.
First off, the axles do look slightly longer than the XLs. Nice 8mm shaft that should hold the hex extenders too. Will get more width than I was thinking.
Planning to get +15mm ofna adapters. Should push it out nicely.
The other good thing is that the weight is half of the XL axles. 25g vs 50g for the above setup. Thats 100g savings total alone. The axles seem strong, and the cvds spin smoothly. Hopefully they last.
The other interesting thing was that the toe plates that came with the suspension set fit the Sav bulks actually quite closely. Some simple mods and they will fit right in. The other bonus is that they came with a bunch of toe plates, all for different toe and anti-squat settings. It would be awesome if I could get these to work!
I overlaid the Sav hinge pin brace over the brace from the mugen. Very close screw mounting. Need to open the holes on the mugen from 3mm to 4mm anyway, should be easy to make it fit. :)
Crappy pic, but I put M3 screws thru the mugen brace, and up thru the HPI on top.
