Do you have room for more gearing? that should do it also. the motor on 4-5s with lipo cutoff disabled (speed runs only) should get you there. The tires on a super are taller than normal tc tires also right?
Yeah...I am running 1/8 scale Serpent type foams thanks to Wolfpack Radicals wheel adaptors. They are pretty close to the outer wheel diameter of the 2.2 wheels and slicks. As for as gearing, I am stuck at 20 due to the limited space I was working with to start with.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
