Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
DUGAN661
11.24.2010, 03:42 AM
hell yea... can a give better step by step on how u fit the 1/5 wheels on there?
im in the process of doing almost the same thing u have =)
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.26.2010, 11:29 AM
Updates
Needing new shafts . ( keep breaking)
You could try to install LST XXL shafts on there. They might not be the exact length you need but you could modify them like you did for your center shafts. You probably would be able to reinstall the original output cups in your diffs. You're pretty good with that drill press so the axle carriers have to be modified just by enlarging the hole for the outer bearing to just under 16 mm. Then you can press a 8X16 bearing in there. The inner bearing is 15X21 and you can press that in the carrier with a 5/8'' socket wrench and a vise. It slips right in.
I'm not sure about your wheels, I went back to try to make sense of how they are secured on but I can't figure it out. I don't know if the wheels use a hex drive and how big it is. I think I read something about them having a square drive?
No brain, no headaches.
