andreazinno
12.03.2010, 03:06 PM
Originally Posted by DrKnow65 View Post
8s is perfect for the 1518 (1800kv x 29.6v = 53,280rpm without a load) IMHO. The datalogging and 5amp BEC should do my buggy right as well :-)
Yes, but a Lipo cell is about 4.2 volts at full charge, so we have to expect 4.2 * 8 = 33.6 volts from 8s and this leads to 33.6 * 1.800 = 60.480 rpm, just above the motor limit
Bye.
12.03.2010, 03:41 PM
Bye.
Just remember two things about that; 1) the voltage will dip under load and 2) that 4.2v value drops pretty fast in less than a minute. Either way, you won't see those rpms for very long, if at all, unless you're running flat out right off the bat.
