BIG-block
12.05.2010, 01:45 PM
So Bodonutz, you run your Castle 1717 on 8S? No issues. I was going to try eventually (when I get the MMMXL) but wasn't sure if it was up to it.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.05.2010, 02:31 PM
I'm geared for 47mph and the RPMs are right at the thresehold of max rpm and still runs way under max temps. Wicked torque and speed.
sikeston34m
sikeston34m's Avatar
12.05.2010, 04:16 PM
When a motor is rated for kv, isn't that an unloaded rating?
8S is what I have in mind for the 1717 also.
Between a little punch control and maybe a little torque control, tame the beast just a little to lessen those amp draw spikes?
What kind of timing are you running with your Bondo?
