toplakd
12.05.2010, 04:28 PM
I have also one XL set of diffs with cups and the flux dogbones do not fit as they are bigger.
Dejan
Originally Posted by thzero View Post
Well, that would be incorrect. The XL and Flux both use the same drive cups and suspension dogbones. The XL axles are just longer by about .5" inches. :)
I removed my signature.
thzero
12.05.2010, 04:38 PM
Im sorry but you are wrong, they do fit. The XL and Flux drive cups are 11mm for the 11mm balls on the dogbones.
Flux Dogbone part #: 86246
XL Dogbone part #: 86246
Flux Drive Cup part #: 86248
XL Drive Cup part #: 86248
Flux Axle: 86928
XL Axle: 86249
I've got two XLs and one Flux. Just saying. And LiqrSicc you should check out my 5T conversion for what i did with the XL axles and the Baja 5B hexes; granted they wont work for your application, but you could do something similiar with the ofna hex adapters if you cant source 5T axles.
Dejan
