Shark413
Shark413's Avatar
12.19.2010, 04:12 PM
I sold my first Z-Car (the one pictured above) but I am putting togther a second one. In my first buggy I ran a 1512 but it gets really hot here in the summer and heat was always an issue. So I switched to a bigger 1515 motor and it ran cool. For my second Z-Car buggy I am going to try the 1512 again (on 4s) and maybe a 1509 on 3s. On my first Z-Car I had the brake servo mounted on an extended center diff mount top plate (along with the esc) so it was completely out of the way of the battery/motor. I think I may run this buggy without the mech brakes and go with a lighter setup using the 1509 on 3s. I also have a Losi 8ight 2.0 and Hot Bodies D8 (both Tekno brushless conversions) and both run big motors (1515) and mech brakes and I want to compare them to a lighter buggy (Z-Car) using motor brakes for comparison.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
el tomaso
01.04.2011, 01:24 PM
I ended up with MMPro and castle/neu 1512 1800kv, on 5s with mec brakes front and rear. I am going to try the 1518 too, just not at first
The mount and tray is RCM, and I have moved the rear brace over to the left side with some modding, this way I have no problems with small pinions. I am using the springs from a hyper 8,5 PRO with the ofna upper spring retainer over the stock spring cup(or what its name is), as adviced in this thread. Much better damping/spring ratio IMO.
If the snow will melt and evaporate, maybe one day I can drive this car too
Here are some low quality pics(long overdue, sorry), of the car almost finished. The wiring will be dealt with, I assure you
That is my little schnauser drinking in the background
Thomas G
el tomaso
02.18.2011, 09:48 AM
The snow finally melted, and I got to try my new LRP buggy on a football-field with short astroturf. It was just amazing, I loved the way it drove, lots of steering on and of power, which I like. I got about 15mins out of the 5s 30C 3200mah battery, which is just fine IMO.
When LVC hit the temps were all under 100f, perfect.
Only problem so far, the centre diff is leaking badly from the hole that has a set screw to seal it. I can guess all three diffs must be rebuilt with silicone/glue to seal the threads of the set-screw. Not fun, but had I read up before the build I'd never have this problem. Its well known.
Thomas G
el tomaso
03.16.2011, 04:35 AM
I got the differentials leak free with new oils(f-c-r , 5000-10.000-3000). I also changed to a xcellorin 1700kv motor, since the color is the same as the alu on the rest of the car Looks great.
This time I went to a gravel/sand parking lot near the woods, which was empty just as I hoped. The LRP buggy worked so well, and looked bad ass with my newly painted shell(I took "before pics" so you can se it before any wear and tear). Again the performance was awesome, this is now my favourite buggy by far. Lots of steering on and off power
IMO the xcellorin 1700kv motor is a great motor on 5s(probably 6s too), lots of low end power and top speed was great in this light buggy.
I will post pics when I get home in a couple of days.
TG
