E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.23.2010, 06:57 PM
I would love to see a spec class motor line from Castle. Even if it isn't the most efficient motor. I would rather support Castle than any other esc/motor manufacturer, they do so much to help members on this forum and provide more info than I've seen from the other companies, plus their stuff is always top notch. So even if it's not Castle's most efficient motor I bet it could be better than the others.
johnrobholmes
johnrobholmes's Avatar
12.23.2010, 09:36 PM
The 2010 rules dictate stator and rotor sizes, stator ID, wire gauge and turns for specific classes, and that 2 pole 3 slot salient pole design is used. It also dictates lamination thickness. While there isn't much room for working around the design, there is still room for improvement within the 2010 specs. An answer that you can't answer would suffice for now Or if you need to take it to email, I have sent one to the engineering email with more specific questions.
---JRH---
