ygguB naM
03.06.2006, 10:17 PM
Originally Posted by Gustav
You're joking right? Didn't you see the yokomo.That'd be one expensive 'fiat' since it costs more that the 'ferrari'
The x10 is still a way cooler car.
Gustav
Gustav's Avatar
03.06.2006, 10:30 PM
Not sure about that,it should have a lower drag co-efficient(by having rockers/inboard shocks but my money would be on the transverse motor every time in modified (or for brushless!)
ygguB naM
03.06.2006, 11:06 PM
The x10 was wind tunnel tested and it's shaft drive so it's better for fast motors.
Gustav
Gustav's Avatar
03.06.2006, 11:18 PM
Don't get me wrong,the x-10 is awesome,no doubt from anyone about that.I nearly bought one.
I was saying the x-10 has the aerodynamic advantage,that's why i mentioned the inboard suspension,that is the reason for this design.
Actually,in 1/10 racing,transverse/belt layouts traditionally have the handling advantage with more powerful motors.That's why in touring car racing, by and large, shafts are used in stock (where the drivetrain efficiency is more of an advantage than the handling benefits of the belt drive layout) and belts are used in modified.
With a longditudinal motor(shaft drive) the motor exerts a rotational force on the chassis,giving inconsistent handling from left to right(undesireable).With a transverse motor (belt drive)this force can be used to create an anti-squat effect under accelleration and an anti dive effect under braking(desireable).
This is the reason both designs exist,they both have different advantages.
ttrmike
got truck
ttrmike's Avatar
03.07.2006, 09:07 PM
Did you finish it?
ygguB naM
03.10.2006, 07:09 PM
I ment that shaft drive is more durable.
Gustav
Gustav's Avatar
03.10.2006, 07:20 PM
Oh,i see what you mean.That's one problem with the Yokomo, it runs open belts like a touring car,so some debris in there could ruin your day.Not much good for messing around off road.The other belt drives in that class are enclosed like the losis and x-5s.
ygguB naM
03.10.2006, 07:41 PM
And belts wear out way faster.
