simplechamp
simplechamp's Avatar
01.05.2011, 02:58 AM
Originally Posted by el tomaso View Post
Use that motor in a SC-truck or other 1/10's that need a little extra power. The KV is just perfect for 3s, I can't understand why anyone would run that motor on 4s.
TG
I don't have a short course or other 1/10 that needs extra power though. As I said in the original post I know it's not the optimal motor choice, it's more of an experiment.
Originally Posted by big greg View Post
that is a 2 pole motor, so you need to max out the timing on the esc for it to run more efficiently, i used 5 degrees on the motor and max on the rx8(whatever that is) i was suprised it was slow and ran nuclear with the timing low and regular gearing, i boosted the timing and geared down and it ripped! and ran post nuclear lol
What was the setup you had the Vector 8 motor in?
I was thinking like you said, gear it with a higher reduction and rely on higher RPM (from voltage and/or timing boost). That's what I thought was best for 2-pole in 1/8 setups.
