Fast5sRevo88
01.05.2011, 02:44 PM
Yes, the spark is still there because no matter if the ESC is on or off, the caps are the parts that cause it.
What i was getting at though is that the switch i had linked would be installed between the batteries and the esc switched to off essentially isolateing the batteries from the caps until everything is connected then turn it on. I dont care if a spark occurs inside the switch as long as i doesnt happen when i plug the batts in.
