Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
01.10.2011, 12:18 PM
I would guess any regular 1/8 diff will fit really, the majority are the same dimensions essentially, just different teeth counts & spur designs ( teeth count is the important factor, and getting spares ofcourse ). Not sure about bearings, but I'd bet they are probably pretty common- the ID will be 5mm most likely, you can check the thickness and OD with some calipers, but I doubt it will be hard to find something suitable- loads of bearing retailers around..
