ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
01.12.2011, 08:18 PM
Motor comparison
Medusa 36x70mm 1600
CC 1520
CC 1717
Photobucket
The 1717 Makes the 36x70mm Medusa look like a 20mm motor…
Photobucket
Kyosho plastic spur lasted about 15minutes…
Photobucket
I thought this was a good shot of showing how simple this CD Mount really is…
Photobucket
Spider gears are now worn in, Oil is “Glittery”, Spur is toast. Time for a rebuild. (After 15min)
Photobucket
Regeared to 50t Spur and 14t Pinion. I had to Clearance the black skid pictured under the 8ight chassis piece. Simple enough. Then I had to clearance the “Support Leg” for the CD Motor Mount. You can see the little notch I cut here:
Photobucket
Photobucket
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
