01.12.2011, 11:14 PM
Thanks for the motor pic Patrick. What kind of output do you think the 1717 is good for?
How would it compare to the larger 15 series? Halfway between a 1521 and a 1527, or closewr to the 1527. I never did run a 1527, but I have plenty of experience with the 1521 and the 1717 seems to be as big or more of a jump past the 1521 as the 1521 is to a 1515. Hope that makes sense. Just trying to get a feel for what that 1717 can do.
Still would like to see a few more 17 series motors. A 1727 would be very nice...
Pdelcast
Pdelcast's Avatar
01.12.2011, 11:17 PM
The 1717 has more torque than the 1520, just because of the larger rotor. I would think it would fall about in the middle between a 1521 and 1527 (just with quick Windows Calculator math...)
We are redesigning the rotor and stator on the 1717 right now -- trying to juice a little more torque, and less torque ripple.
Patrick del Castillo
President, Principle Engineer
Pdelcast
Pdelcast's Avatar
01.12.2011, 11:21 PM
Sorry -- forgot to answer your first question!
The 1717 is good for about 3kW in bursts under 5 seconds, 1 minute power is about 900 watts.
We use 1717s on some of our burn-in rigs (for military controllers) with forced air cooling, and they run upwards of 8 hours at a time at 500W output.
It's all about the heat... keep it cool (which means operate around the good efficiency range), and you can put tons of power through it.
