George16
Supermaxx
George16's Avatar
01.14.2011, 05:58 PM
Or you can put a longer screw so you can use a lockwasher to keep it in place. This is how I mount my motors.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
AMorgan
01.14.2011, 06:02 PM
Hrm, I may just try torqueing it a bit then. I'm using 4mm screws and this motor has only been used for 3 race weekends with 2 DNFs. I was also thinking about making the bottom screw a flanged bearing supported screw to give it some support down there. I usually give it a good torque down and use some loctite. I'll trying running it some more and see if I get the same result. I only got 3 tests on it before my brand new servo went bad, so I'm waiting on good weather to try again.
brushlessboy16
brushlessboy16's Avatar
01.14.2011, 07:42 PM
Mike is in the process of making a lower flanged bushing (not that the mount needs it). But its peace of mind
